8 series to 0i things to watch out for
  • FuserNoob
    Service Mgr, CISSP
    • Jul 2022
    • 149
    Hi All,
    We just received an off lease batch of 0i machines, and I'm starting to familiarize myself and my staff with them.
    I'd appreciate the benefit of the community experience in regard to differences, pitfalls and other things to be aware of.
    Thanks!!
  • Slammers
    • Feb 2019
    • 136
    There is a thread here with the best practices guide as these machines can be a bit fragile if not taken care of properly.
    https://www.copytechnet.com/forum/te...-i-series-v1-6
    In my fleet i have only really had issues with the Subhopper paddles causing TCR issues and a few machines with issues with the scanner light bar.
    I have always felt they have been a bit less robust physically and mentally (SSD board issues) than the previous 8 series.
    Colour reproduction was a bit off at times too, which can be sorted with info from this thread:
    https://www.copytechnet.com/forum/te...mes-out-orange
    All in all I have come to like this series.
    • FuserNoob
      Service Mgr, CISSP
      • Jul 2022
      • 149
      Originally posted by Slammers
      There is a thread here with the best practices guide ....
      You're awesome, Slammers!
      Thanks!
      • Duplicator
        • May 2022
        • 246
        +1 on a lot of that... as mentioned they print color/black differently. There will be a noticeable change in color output. Also it will eat K toner faster.
        Be ready for CPU board issues, and SSD issues.
        Get your hands on the Diag firmwares and the brand new CPU firmware upgrade firmware.
        Worked in IT for 12 years from Helpdesk up to System Administrator. Now working as the IT Manager at a copier company for the last 4 years.
        If I helped you out, please give me a thumbs up! It helps my reputation.
        • tsbservice
          Field tech
          • 8020
          It's now essential to update firmware, boot rom, cpu and function version to latest. As long you don't have to change CPU board or SSD they are pretty close to 8 series. That said there are numerous small things to watch for, same as any copier line before. You should be familiar with them very soon if you know 8 series well
          • FuserNoob
            Service Mgr, CISSP
            • Jul 2022
            • 149
            I got the Firmware, Boot ROM and Function Version updated on the C360i I'm playing with. Any help on the CPU update? What would I search in One Stop?
            • Ziggy
              • Feb 2018
              • 763
              Recommended to update boot rom before firmware
              • Ziggy
                • Feb 2018
                • 763
                Another thing to note , NEVER Clone the security or certificates from an 8 and try to put on an i . you will brick the i. It is safe to clone all other settings.
                • Ziggy
                  • Feb 2018
                  • 763
                  Here are a couple of good bulletins on page 5 of 13472 it explains how to update boot rom
                  • Slammers
                    • Feb 2019
                    • 136
                    These are great. Thank you.
                    • Duplicator
                      • May 2022
                      • 246
                      Look for something like "AA2J0Y0-F000-GXX-42.exe". It's under special firmware. GXX-42 is for a C250i/C300i/C360i. It's called "Power Control CPU2(LPPP) and MFP Controller BOOT program FW for C5372 (CPU temperature failure)." Look at page one of the readme PDF. It will show all the firmwares to download under "Jig Firmware".
                      Not sure if it was uploaded yet but attached is the PDF that comes with it.
                      Also while you are in the special firmwares download the diagnosis and recovery tool for each model. This tool will check for and help recover from bad SPI flash and bad SSDs. Please be aware there are 2 versions. Using the older version at this point may create false postivies. Using a C250i/C300i/C360i again for an example the one to download is "AA2J0Y0-F000-GXX-34.exe".
                      • FuserNoob
                        Service Mgr, CISSP
                        • Jul 2022
                        • 149
                        Great info! Thanks!
                        • Duplicator
                          • May 2022
                          • 246
                          Great info! Thanks!
                          No problem. Anytime.
                          • FuserNoob
                            Service Mgr, CISSP
                            • Jul 2022
                            • 149
                            I had to update the CPU FW individually on the C360i, but according to the Program Release PDF for the RE firmware version for the C450i includes the CPU update? At any rate, I wasnt able to find in on One Stop.
                            Here's the C450i CPU FW after updating to G00-RE:
                            Power Control CPU1=AA7N0Y0-2100-G00-14(00)
                            Power Control CPU2=AA7N0Y0-2000-G00-07(00)
                            • Duplicator
                              • May 2022
                              • 246
                              AA2J0Y0-F000-GXX-42 came out after RE. We have had to update the CPU "power control" thingy (CPU core voltage setting maybe???) while RE is already installed. Maybe they updated the RE package silently? Not sure.
                              Look under special firmware. It's the first item.
