C224e Anomaly
  • Massimiliano
    • Oct 2019
    • 48
    C224e Anomaly
    Good morning everyone,
    I have a problem with a c224e with this error on the screen:
    " only black and white printing is now possible" and "fax cannot be used currently"
    it prints and copies in color the same and fax is not even installed.
    Can anyone give me a tip?
    This gallery has 1 photos.
  • Synthohol
    Certified Konica Expert
    • 5839
    try a trouble reset?
    may be hdd related?
    • tsbservice
      Field tech
      • 8019
      Maybe a battery is due or HDD as Synthohol mentioned.
      • Massimiliano
        • Oct 2019
        • 48
        hdd replaced but not solved, which battery should be changed?
        • Synthohol
          • 5839
          lets see the most recent trouble, warning and jam codes before any surgery, maybe a clue there.
          • AlaskaCopyTech
            • Jan 2024
            • 78
            Normally "cannot be used" is when something is disabled in service mode regardless of whether or not that thing is installed. Check problem unit isolation set.
              • 23008
              Are any of your color consumables past life? You'll need to replace those, before turning off that function.
              CORRECTION:
              Oops! I see that you can print in color. hmmm, are you using user ID's and maybe have a limit set?
              • Ziggy
                • Feb 2018
                • 761
                go in service mode. press stop>0>c . go to life stop and turn all off
                • tsbservice
                  Field tech
                  • 8019
                  What have you done prior and missed to tell us?
                  With 4e series most of strange things happen with backup battery going flat. It's 2477 button type battery not hard to see on MFP board.
                  • copyman
                    Owner / Technician
                    • Sep 2005
                    • 4712
                    Don't think is has anyting to do with battery. If time, date & meters are correct then it's not battery. I would look more at an overlife consumable, etc
                    • Massimiliano
                      • Oct 2019
                      • 48
                      good morning and thank you all for your interest.
                      I have been a konica technician for about 5 years.
                      consumables are 70% drum and 90% developer.
                      no active user authentication setting
                      life stop off
                      it is an anomalous thing for me, also because as I wrote it prints and copies in color without problems..
                      there is also an error fax is currently unavaiable even if no fax card is installed
                      tsbserviceโ€‹ (I can't figure out where the battery you say is located, can you help me? Thanks)
                      • Synthohol
                        • 5839
                        its a coin type battery soldered to the MFPB probably covered in green or yellow plastic immediately to the top right of the SSD board.
                        • tsbservice
                          Field tech
                          • 8019
                          See the link: https://www.ebay.com/itm/266249200329
                          It's yellow one below fan.
                          • Massimiliano
                            • Oct 2019
                            • 48
                            ok thanks I was doubtful it was that one...
                            never changed this battery, do I have to take some precautions or just replace it with another one?
                            Many thanks
                            • adecanmin
                              • Oct 2010
                              • 316
                              Many thanks
                              When soldering. The battery gets hot. If possible use some kind of heat sink. Maybe hemostats? Taped so the metal doesn't touch the board.
