I have a customer ask if there was a way to print a confirmation page when scanning? Not sure if I understood them correctly but think they may scan directly to an email address and wanted a receipt the scan was successful? I told him the job history should show results. I may be wrong but only confirmation pages available are for faxing which this machine does not have fax installed. Thanks
C3350i confirmation page?
KB0027367 Transmit confirmation reports for Scan to Email
Article metadata.
5mo ago5 months ago
This article has 38 views.โข 38 Views This article has average rating: 0 out of 5 starsโข ( )( ) ( ) ( ) ( )
Is there a transmittal confirmation report available when scanning to email whether using a relay SMTP server or directly to an SMTP server?
No, there is no confirmation report available from the MFP when scanning to email. However, there are methods that can be utilized to reasonably confirm that the message was sent successfully
1) The User Guide for the MFP includes an Error Code list in the Troubleshooting section
a) There is a list of Error Codes pertaining to Transmission (E-mail/Internet FAX/IP Address FAX)
i) If the scan sends, and there is no error code, then success is probable
(1) See picture below of User Guide entry and random selection of codes displayed
2) Have the sender CC themselves on the transmission
a) If the sender receives the email then success to other destination(s) is probable
Related Products
bizhub C258, bizhub C368, bizhub C458, bizhub C558, bizhub C658, bizhub C659, bizhub C759, bizhub C250i, bizhub C300i, bizhub C360i, bizhub C450i, bizhub C550i, bizhub C650i, bizhub C3350i, bizhub C4050i, bizhub C224, bizhub C224e, bizhub C284, bizhub C284e, bizhub C287, bizhub C364, bizhub C364e, bizhub C454, bizhub C454e, bizhub C554, bizhub C554e, bizhub C654, bizhub C654e, bizhub C754, bizhub C754e, bizhub 224e, bizhub 227, bizhub 284e, bizhub 287, bizhub 308e, bizhub 364e, bizhub 367, bizhub 368, bizhub 454e, bizhub 458e, bizhub 554e, bizhub 558, bizhub 558e, bizhub 654, bizhub 654e, bizhub 658e, bizhub 754, bizhub 754e, bizhub 808, bizhub 958, MFX-C5590, MFX-C4590, MFX-C3690, MFX-C2590, MFX-C2860, MFX-C2280, MFX-C2880, MFX-C3680, MFX-C4580N, MFX-C5580N, MFX-C3680N, MFX-C2880N, MFX-C2280N, MFX-3680N, MFX-4580N, MFX-C2595i, MFX-C3095i, MFX-C3695i, MFX-C4595i, MFX-C5595i, MFX-C6595iโ๐ 1 -
Just thought about this. They can login to the email that they use to scan and check their sent folder. At least in gmail you will get a failed to send message in your inbox if it doesn't go and in your sent folder you can see all that you have sent๐ 1Comment
Sounds funny - "probable"
Thanks for posting this.A tree is known by its fruit, a man by his deeds. A good deed is never lost, he who sows courtesy, reaps friendship, and he who plants kindness gathers love.
Blessed are they who can laugh at themselves, for they shall never cease to be amused.๐ 1Comment
I have a customer ask if there was a way to print a confirmation page when scanning? Not sure if I understood them correctly but think they may scan directly to an email address and wanted a receipt the scan was successful? I told him the job history should show results. I may be wrong but only confirmation pages available are for faxing which this machine does not have fax installed. ThanksTip for the day; Treat every problem as your dog would.....If you cant eat it or f*ck it....then p*ss on it & walk away...Comment
Best advice here would be to scan it to yourself and then forward it on if it's being sent to someone outside your organization. Sending directly is generally not a good idea. Most people on the receiving end won't be able to comprehend that the email came from a machine and that most likely the email address it was sent from is not monitored. If they just click reply, their reply will likely never be seen by anybody, and that makes for bad customer relations.A Ricoh Service Tech for 7 year. A Konica Minolta Service Tech for 7 years. Now, KM service manager for 4 years.
My Ricoh knowledge is slowly dwindling away at this point. Many things have been lost to time...๐ 4Comment
