C224 blank pages
  • copyman
    Owner / Technician
    • Sep 2005
    • 4717
    #16
    If the developer wasn't turning would machine still give a good level history reading? The OP said level was good at 6%. This is why I ruled out dev unit not turning.
    • mrfuser
      • 1621
      #17
      It was indeed sd4 solenoid. First one I have seen die
      • copyman
        Owner / Technician
        • Sep 2005
        • 4717
        #18
        Thanks for update. Good to know. Looks like it was a common problem and surprised I never saw it. I was servicing quite a few of the 4 & 4e series a few years back and never had that sol go bad.
        Does this only happen to higher volume machines? Does it happen with the 8 series or Kon Min fix it?
        Was there a bulletin on this? I've scanned the TSB's hundreds of times and don't recall seeing that.
        • mrfuser
          • 1621
          #19
          First I’ve ever ran into this also in my 35 years. Annoying little repair
          • copyman
            Owner / Technician
            • Sep 2005
            • 4717
            #20
            May I ask what was meter on this machine?
            • kingarthur
              • 1366
              #21
              Yes, which is the annoying thing, no errors are usually displayed.
              • KMFLT3CH
                • May 2017
                • 241
                #22
                Yes, I've replaced SD4 on a few 8 series, both low and high meter. It seems more common on the 4 series but we only have a few of these in the field now.
                No bulletin exists on this that I know of.
                • mrfuser
                  • 1621
                  #23
                  Meyer was about 150,000 total
                  • adfgdf
                    • Jan 2022
                    • 12
                    #24
                    Unfortunately, in all KM copiers and printers (and not only those) the solenoids might cause problems.
                    Usually, the (black) insulating material used to prevent noise - melts, causing the metal arm to stick and not return properly as the electro-magnet is not strong enough.
                    Usually you can fix that with a patent, by lowering the distance between the metal arm and the electro-magnet.
                    • femaster
                      • May 2011
                      • 1512
                      #25
                      Wow, we have had hundreds of 4, 4e, 8 and 8e machines out in the field over the years (606 machines past and present to be exact), and to date have yet to see a single solenoid (SD4) failure. Keeping my fingers and toes crossed!!
                      • copyman
                        Owner / Technician
                        • Sep 2005
                        • 4717
                        #26
                        Same here. This is why I was surprised because I never saw this issue or even heard about it! I haven't replaced a solenoid in 20+ years! I've had a few HP solenoids where I had to remove the sticky pad and replace with a new pad but solenoid was still good. Very rare a solenoid goes bad. All the bulletins adressing no toner in sub hopper and never did I see anything about this solenoid?
                        • kingarthur
                          • 1366
                          #27
                          Me too - never had a solenoid fail
                          • Zoran
                            • 51
                            #28
                            Check the 2nd transfer, I've had cases where the plastic support for the 2nd roller breaks or the spring that transmits high voltage to the roller falls out.
                            • mrfuser
                              • 1621
                              #29
                              see above repair was completed via solenoid
                              QUOTE=Zoran;n1621340]Check the 2nd transfer, I've had cases where the plastic support for the 2nd roller breaks or the spring that transmits high voltage to the roller falls out.[/QUOTE]
