Negative ghosting
+ More Options
Posts
  • Benioffi
    • Jun 2025
    • 8
    [Misc] Negative ghosting
    Hello. I'm new to the forum and need some help. I have a client with a Konica Minolta Bizhub C550i showing an issue I haven’t been able to resolve.
    Some time ago, I replaced the black drum unit. Shortly after, the client reported dark areas appearing on the prints. The problem is that starting from the second page, a band from the previous print is repeated in negative (see attached images).
    I tried replacing the drum again, but the result was the same. I’m considering whether it could be an issue with the erase lamp, but I don’t want to start replacing parts without being reasonably sure of the root cause.
    If anyone has experienced something similar, I would really appreciate your help.
  • Larhal
    • 568
    Did you use a original Konica drum? Was this happening before you first serviced the machine?
    Larhal
    If all else fails read the Service Manual!
    If that fails, meet me at the pub and we will discuss it.
    • tsbservice
      Field tech
      • 8008
      +1
      It looks like drum is not properly discharged.
      • copyman
        Owner / Technician
        • Sep 2005
        • 4684
        drum or fuser
        • Larhal
          • 568
          +1
          I confirm that but still is it an compatible drum or Konica?
          Larhal
          • Benioffi
            • Jun 2025
            • 8
            I often use Katun drums and usually have no issues, but in this printer I installed an original Konica DR618K. I replaced it because the counter had reached zero. The machine wasn’t having this specific issue before—there were marks due to the worn-out cleaning blade. However, I’ve now installed a third new drum and I'm still getting the same problem.
            • Benioffi
              • Jun 2025
              • 8
              +1
              I think I’m going to disassemble and clean the drum contact areas inside the printer, and also check the erase lamp and its connection.
              • Benioffi
                • Jun 2025
                • 8
                Originally posted by copyman
                drum or fuser
                The ghosted image that repeats is intermittent and appears in negative, which is why I ruled out the fuser as the cause. I replaced the drum with another new one, but the result is exactly the same.
                • SAR
                  • Jul 2009
                  • 203
                  I had one doing that exact same banding, but it was only on the back side of the page, if it was a single sided copy and was on page 2 of a double sided copy.
                  It ended up being a bad transfer roller that caused it.
                  This may not apply to your circumstances, but if it does, it only takes a few seconds to pop a transfer roller in.
                  • Benioffi
                    • Jun 2025
                    • 8
                    Yes, one of the solutions I considered was replacing the secondary transfer roller. But the problem is not on the second side of the sheet. Honestly, it's easy to replace, so I might try it to rule out that possibility.
                    • tsbservice
                      Field tech
                      • 8008
                      Then check your erase leds.
                      • Black Cloud
                        • 161
                        It could also be developer bias, While you are cleaning drum contacts, go in there and clean out the developer contacts also. A bit of fine sandpaper should do the trick.
                        Net+ PDI+ @Remote
                        • Benioffi
                          • Jun 2025
                          • 8
                          Hi everyone. I disassembled the transfer belt, drum units, developer units, fuser, and even the secondary transfer roller.
                          I cleaned the springs and contacts that connect the drum and developer units using isopropyl alcohol, cleaned the K erase lamp, and visually inspected everything. I then reassembled all the components, entered service mode, and executed a drum refresh for K.
                          And it started working normally again. I don’t know which of all the actions I performed actually fixed the issue, but if it’s working, I’m happy.
                          Thank you all for your help. Best regards.
                          • Larhal
                            • 568
                            Was anything you cleaned excessively dirty? Congratulation on your success.
                            Larhal
                              • 23007
                              Did you reset any counters, do any color calibrations after replacing the black drum?
