Hello. I'm new to the forum and need some help. I have a client with a Konica Minolta Bizhub C550i showing an issue I haven’t been able to resolve.
Some time ago, I replaced the black drum unit. Shortly after, the client reported dark areas appearing on the prints. The problem is that starting from the second page, a band from the previous print is repeated in negative (see attached images).
I tried replacing the drum again, but the result was the same. I’m considering whether it could be an issue with the erase lamp, but I don’t want to start replacing parts without being reasonably sure of the root cause.
If anyone has experienced something similar, I would really appreciate your help.
