The Best Electric Screw Driver
  • Jinn
    • May 2023
    • 122
    Hi Experts,
    I am new into this field and I am tired of rotating screw driver manually. I am looking for electric screw driver so I want you to give your suggestion which electric screw driver I should purchase. Keeping in view your experience.
    Also which one is the best, manual or electric ?
    Is there electric screw drivers with long bit and magnetic tip?
    Please share your experiences
    Many thanks
  • Brad6784
    • Mar 2015
    • 77
    Good morning,
    Welcome to the wonderful world of copiers and printers!
    Personally after 25+ years in this industry, I’ve never found an electric screwdriver that works for me but these days, I’m sure there are models that are more suitable. I just want to get my tool bag out and work, not worry about batteries not being charged or the noise of the screwdriver that I’ve had complaints about before.
    I’m sure someone with a better experience of electric screwdrivers will be along soon to help you decide which products to take a look at!
    Good luck in your new job, mostly this industry has been good to me and the support and help I’ve received on this site, has been second to none!
    • Hart
      • Feb 2024
      • 403
      I have a Bosch Go 2, the minimum torque is perfect for copier.
      • Samanator
        • Sep 2017
        • 579
        I have a Hitachi DB3DL2 electric screwdriver. I bought on Amazon quite a few years ago. I have been very happy with it. The one I bought came with two rechargeable batteries, a charger, and a case. The screwdriver comes with a variable speed switch(high and low), variable torque knob (I usually set it to 5, it will go up ti 21), a small flashlight with a switch on the handle (very handy when peeking into the crevasses of a machine), and a lock for the forward/reverse switch (so when you toss it in your bag the switch isn't accidentally be made and run it down), and the handle will brake over so one can use it as pistol grip. It also come with a case that I now use to hold various feed rollers. When I got this screwdriver, I put a red sharpie mark on one battery so I could tell the two apart. I always charge the discharged battery when I get home then put it in a plastic bag I keep in my tool bag. Takes about an hour or so to charge up.
        I found and purchased two different P2 bits. A 3.5 inch (90mm) and a 6 inch (150mm)as the short bit that come with the screwdriver are not that useful. One can usually find these screwdriver bits at any Home Depot or Lowe's or on Amazon.
        A couple years ago I purchased a set of magnets that slip over the shaft of the bits. I have found this very handy keeping the tip magnetized. Many time I will slip the magnet off and use it to keep the screws I take off in one place. Here's a link to the magnets: https://www.amazon.com/s?k=screwdriv...tr-ranker_1_19
        When I search for on Amazon for a Hitachi DB3DL2 electric screwdriver, I was directed to Metabo HPT DB3DL2. It looks to be the same screwdriver, just different name.
        Here's a link to the screwdriver: https://www.amazon.com/Metabo-HPT-DB...72J/ref=sr_1_2
        I have found this tool to be very helpful and reliable and have had it for many years. I have had a couple of different screwdrivers before this one that didn't last very long.
        I suggest you do a little research before you buy. I hope this has been helpful.
        • BR549
          • 111
          I use a Dewalt DCF680 and it is the best investment I ever made in a tool. Amazon sells it for $124 but says out of stock for now. I'm sure they're cheaper options but this is my #1 tool that I make my living with. That comes with 2 batteries, charger and the bag. Tips must be bought separately. I use a Dewalt P2 tip. It's 6" long. Don't get a cheap tip. Most any screwdriver and tips can be magnetized by rubbing a magnet on it from top to bottom and must be remagnetized periodically. It works gyroscopically. Pull the trigger, then turn whichever direction you want it to turn. The more you twist the faster it goes, until of course it's maxed out. The torque can be set from 1 to max. I usually keep it on 8. When you let go of the trigger, it automatically locks so you can loosen or tighten manually. Light comes on when you press the trigger and then times out after a few seconds. Adjustable, pistol grip or straight. I've had it about 6 years and I love it. It was recommended by a coworker. He's got 2. After he bought his second one (had it for quite a few years) he sent the old one in to Dewalt for repair and they fixed it for free.
          • Albonline
            • Sep 2008
            • 1150
            I found powered screwdrivers to be totally useless. too slow
            • copyman
              Owner / Technician
              • Sep 2005
              • 4700
              I use a Panasonic 3.6 v li ion (see pic). Small and balanced. Fast and slow speed with torque. Battery charge last a month. It's the most used tool in my bag.
              • ThisPete
                Too old to care
                • Jun 2014
                • 207
                I'm watching this thread with interest, and as a 'tool head' I'm finding it difficult to not pull the trigger on an electric screwdriver.. however as we mainline in Kyocera, I don't know that I use screwdrivers anywhere near as much as I used too in day to day maintenance..
                Kyocera's rarely need a screwdriver and combine that with the fact that I do a lot of network issues/installs I'm finding it hard to justify.. 😢
                • Hart
                  • Feb 2024
                  • 403
                  When you have to access the back of the copier you're happy to have an electric screwdriver.
                  • copyman
                    Owner / Technician
                    • Sep 2005
                    • 4700
                    Lol, my exact thought. The Jap's over screw everything!
                    • Slammers
                      • Feb 2019
                      • 136
                      Personally, if I see any of my techs assault one of my copiers with an electric screwdriver they get shot.
                      These are delicate machines, and the screw quality has decreased over the years, some screws just strip if you look at them funny.
                      I use one of the Linus Tech Tips ratcheting screwdrivers, pricey, but has great bit storage, really strong magnet and the smoothest ratchet mechanism I have ever used. Had a second hand Snap On one before hand and this thing wins hands down. I use a pack of Bosch Magnetic tips to replace the ones from the original set when they wear out.
                      If i need to get to a screw thats deep in the chassis I just use a long length magnetised PH2, currernt is Ebauer. I also love the Wera drivers for other jobs, and I have a Klein Tools MultiTip driver for small work.
                      Electric screwdrivers are fantastic in the correct applications, copier tech work is not one of them
                      • Ziggy
                        • Feb 2018
                        • 732
                        I love may Makita. Has several torque settings , If you leave it on 2 you will not have a problem overtightening the small screws and I usually use 8 for the bigger screws. I caught mine on sale for $130.00 U.S.
                        https://www.amazon.com/dp/B071F4XTPK...t_details&th=1
                        • Ziggy
                          • Feb 2018
                          • 732
                          Its also a good idea to use JIS bits. they fit the screws better. Even if you use a standard screwdriver still use a JIS bit or JIS screwdriver. They cost more but fit the screws better.
                          • ThisPete
                            Too old to care
                            • Jun 2014
                            • 207
                            Kyocera A3 machines have been one screw for the upper rear cover and two for the lower rear cover for a long time now, what do you mainly work on?... 🤷‍♂️
                            • copyman
                              Owner / Technician
                              • Sep 2005
                              • 4700
                              Konica Minolta is my main brand. Even though they are using less screws now a days it's still way more than necessary! My elec screwdriver still helps a lot!
