Why do 2 of my machines have ORANGE toner?
  • 907tec
    • 434
    OK. I've got a weird one for y'all: orange toner.
    Back story: A few years back, I received a service call for a C454 located at a remote mine. During troubleshooting for some minor issue (jamming I think?), I had them send me some photos of the machine. In these photos, I could see very clearly that there was orange toner scattered around the K toner cartridge slot. orange toner scattered around the K toner cartridge slot. Not yellow, not a waste-toner mix, but actually orange.
    The machine is a real pain to get to, and I was able to resolve the jamming issues remotely, so I didn't think too long about it. Fast forward 2-3 years, and I am out visiting the same mine working on a different machine that is located on the opposite side of the building. This one is a C554e. Imagine my shock when I open the toner door and see ORANGE TONER scattered only around the K toner slot. Normal amounts of CMY toner scattered in front of those slots, but distinctly orange toner around the K.
    I've been wrenching on these things for nearly 20 years, only two times I've encountered this have been in this one building. It is the mill at an underground metals mine, so there is definitely a smell/taste to the air inside.
    Is it possible that there is something in the air that is reacting with the toner and turning it orange? Maybe oxidizing the ferrite particles rapidly? It hasn't really been an issue yet, but it is perplexing me.
  • Ziggy
    • Feb 2018
    • 770
    Re: Why do 2 of my machines have ORANGE toner?
    [ATTACH=CONFIG]61704[/ATTACH]
    I think you are correct that something in the air of the mine is reacting with the toner causing it to turn orange
      • 23009
      It's not the typical canary yellow, but still maybe sunflower yellow? I suspect that it's generic toner, slightly off color. =^..^=
      • tsbservice
        Field tech
        • 8020
        I would say developer in K toner bottle is rusting, others CMY too but it's hard to see in them.
        • 907tec
          • 434
          They're on contract, all toner is included so I hope they aren't buying generic. Bottles in the machine appear to be genuine and I haven't seen any evidence that they are using generics. It IS a mine, so I would not be surprised at all to find out that these knuckleheads have messed with the machine in some way. But... Sourcing generic toner with their requesition process seems difficult, at best.
          • copier tech
            • 8172
            Could be that in the past they've fitted a yellow toner in the black slot, so that orange is a mix of black / yellow, but you say no issues with print quality!?
            • femaster
              • May 2011
              • 1514
              That was my first thought as well.
              • Larhal
                • 584
                If the K developer was rusting it would cause CQ issues long before that light dusting shows due to the resistivity of the carrier particles. I noticed the C toner was dusting also. I has to do with the Y and M toner dusting in that environment as they are prior to the K toner area. Has to be the environment that the unit is in.
                If you ever noticed the K drum and dev units get covered in a dusting of Y, C,M toner in many different machines?
                Larhal
                If all else fails read the Service Manual!
                If that fails, meet me at the pub and we will discuss it.
                • dalewb74
                  • Feb 2018
                  • 1157
                  hopefully there are no oompa loompas in the mine. sorry just couldn't resist......
                  • 907tec
                    • 434
                    No copy quality issues on these machines that I have seen. Normal amounts of toner scattered around each of the drum areas, certainly nothing like I've seen on other 4-series when the cyan contaminates the K drum.
                    I agree that if the K dev was rusting in the tank it would cause all sorts of issues, but it appears as though the 'orange' reaction is only occurring on loose toner that is exposed to the environment for long periods of time. Like the spilled toner on the inside surface of the door will have more exposure to the elements than toner inside of a bottle/tank/etc that is constantly replenished and agitated. That's the best theory I've got, at least. Very open to hearing other takes on this.
                    • allan
                      RTFM!!
                      • 5462
                      Is developer not rust already?
                      Can Fe3O4(black) turn to Fe2O3(red) I am no chemist but isn't that called reduction not oxidation?
                      Whatever
                      • allan
                        RTFM!!
                        • 5462
                        Yea I am wrong black rust is lighter than red rust so yes oxidation will turn black rust into red rust. I can still be wrong. You will need a lot of heat to go from red to black. Could then just need oxygen and water to go from black to red. Use to make black rust by burning red rust with a cutting torch to make a better burning thermite. Wonder how that will happen in that environment. But that is developer not toner.
                        Then there is this stuff - Yellow Rust. Iron oxide-hydroxide FeO(OH)H2O
                        Whatever
                        • judgedredd
                          • Feb 2024
                          • 47
                          What type of mine is it?
                          • Larhal
                            • 584
                            One thing is that Toner itself is a inert plastic powder How would plastic react with something else. Yes there is surface treatments on the toner for flow and cleaning aids, etc. Just curious of the environment they are in.
                            Larhal
                            • Saturn
                              • Nov 2023
                              • 171
                              Never seen orange Toners. If this exist, it would be nice for all the Dutch people Could it be an early April Fool's joke?
                              I don't care about who your father is, as long as I'm fishing here, you won't walk on water.
