More i-series problems
  • Ziggy
    • Feb 2018
    • 776
    Noticed that on A4 printers and MFP's that the vent hole in the cover for the CPU does not line up with the actual vent holes for CPU. Which could cause CPU overheating and eventually CPU failure. Picture attached of a 4750i , I checked several other A4 machines and all were same way.
  • elmaligno
    Expert technician KM
    • Oct 2009
    • 302
    Re: More i-series problems
    . C5372 (CPU temperature failure) may occur during PC printing or low power/sleep mode.
     As a countermeasure, the FAN will not turn off even in low power mode or sleep mode after applying this firmware (GG1-RB).
    For the customer who prefers to stop CPU FAN, it is required to set the following software SW to disable the countermeasure.
      A function to turn ON/OFF the CPU FAN during low power and sleep mode.
    Field technician since 1994
    • Ziggy
      • Feb 2018
      • 776
      Yeah but if the vent holes were in the correct spot it would alleviate this problem.
      • Woxner
        • Jul 2011
        • 851
        You would be nuts to put RB on right now. it just came out on the 18th. Give it a month for bugs to be worked out
        • tsbservice
          Field tech
          • 8020
          This is frightening even for POS they are. QA in KM production is at its lowest end ever. Yet they continue to dig down.
          • Gift
            • Mar 2011
            • 2459
            lol - never noticed, we once had a c300i with overheating issues - we swapped the thermal conductive pad from the cooler with a qood quality grease and that helped, too.
            • copier tech
              • 8172
              Wow that really does look like a design flaw!
              • KMFLT3CH
                • May 2017
                • 241
                Just released today...
                CAUSE: G00-K8 firmware contained a change designed to reduce the noise output of the printer.
                This was accomplished by turning off the CPU cooling fan during low power and sleep mode.
                A side effect of disabling the CPU cooling fan is the generation of C5372 errors.
                SOLUTION: It is NOT recommended that holes be drilled into the back panels of the printer.
                Many notice that the rear exhaust grill is not aligned with the fan vent in the RF shield, this is intentional and does not affect the CPU cooling fan's performance.
                (lol)
                The offset of the exhaust grill reduces the noise level of the CPU fan.
                To resolve the intermittent C5372 errors, apply the countermeasure firmware below.
                Occurrence models / Countermeasure firmware
                bizhub C4050i/C3350i, C4051i/C3351i .... GG1-RB
                bizhub C4000i/C3300i, C4001i/C3301i .... GG1-RB
                bizhub C3320i, C3321i .... GG1-RB
                bizhub 4750i/4050i, 4751i/4051i .... GG1-RB
                bizhub 4700i, 4701i .... GG1-RB
                *Periodic FW scheduled to be released in May will also include the same countermeasures as GG1-RB*
                For the customer who prefers to stop CPU FAN, it is required to set the following software SW to disable the countermeasure:
                Software SW No. 189 (bit7)
                Hex: 00 (Enable [default]) FAN is turned ON in low power/sleep mode
                Hex: 80 (Disable) FAN is turned OFF in low power/sleep mode
                • kingarthur
                  • 1369
                  I had no choice, had a brand new device, constantly sending me C5372 errors via CSRC - luckily the customer was unaware, however, since updating the FW over a week ago, I've had no notifications
                  • Gift
                    • Mar 2011
                    • 2459
                    (lol)
                    LOL seems like KM is checking out the forum
                    • Ziggy
                      • Feb 2018
                      • 776
                      (lol)
                      Just curious where did you find this on the KM site? I cant find it
                      • tsbservice
                        Field tech
                        • 8020
                        I can send it to you though mine isn't from MKM US site. Let me know. BR
                        • Ziggy
                          • Feb 2018
                          • 776
                          I sent you my email via PM
                          • stronghold
                            • Apr 2023
                            • 47
                            I hope this helps.
                            <Bug fix> Power Control CPU2(LPPP) and MFP Controller BOOT program FW for C5372 (CPU temperature failure)
                            [Download File Name]
                            FW_ACKN0Y0-F000-GXX-27.exe
                            FW_AA7N0Y0-F000-GXX-27.exe
                            FW_AA2J0Y0-F000-GXX-42.exe
                            FW_ACV70Y0-F000-GXX-27.exe
                            FW_AC740Y0-F000-GXX-41.exe
                            FW_AC770Y0-F000-GXX-43.exe
                            FW_A93E0Y0-F000-GXX-37.exe
                            FW_AAJT0Y0-F000-GXX-32.exe
                            FW_ACT90Y0-F000-GXX-22.exe
                            FW_ACTA0Y0-F000-GXX-18.exe
                            FW_ACM10Y0-F000-GXX-24.exe
                            PRI_DLKM_BT2414590EN_**.docx
                            2. What changed
                            1. Optimize the voltage applied to the CPU and reduce the heat generated by the CPU.
                            3. Cautions and Restrictions
                            *This special FW only updates the Power Control CPU2 FW in the CPU board.
                            After updating the FW, please check the version of “Power Control CPU2” is updated in service mode.
                            *If turning OFF the main power during the FW update, the machine won’t boot up. CPU board must be replaced.
                            Please make sure not to turn OFF the main power during the FW update.
                            4. How to install
                            * USB stick
                            * Remote FW update using such as WWRSPF and Fleet RMM, etc.
                            • copier tech
                              • 8172
                              Konica Minolta always over engineer the electronic / digital / software side of their devices, paranoid about counter resets, preventing us from swapping boards to narrow down or resolve an error or fault.
                              If you compare to Ricoh it's very rare to get these sort of software error / crashes. Yet if you want to reset the main counters all you do is replace the NVram chips which are cheap & can be bought from Ricoh.
