Kyocera 7002i thick solid black line
  • sparkycivic
    • Apr 2017
    • 348
    #106
    Re: Kyocera 7002i thick solid black line
    the bulletin looks precisely like a 4551 I had last year with a roasted LKU K polygon motor
      • 23010
      #107
      I just check the records, and it was 18 months and 265K images since the last occurrence. Not as frequent as I imagined. =^..^=
      • chris@kokstadcopiers
        • Jul 2014
        • 14
        #108
        Originally posted by Necrocannibal
        Looks similar but different machine. I haven't called it yet but we swapped the transfer belt from a different machine that had the old style belt without the yellow dot on it and so far we haven't had any issues. I was going to give it another week or two before saying it was corrected but will definitely update this thread when we call the customer next week and ask how it is doing.
        Did the old transfer belt without the yellow dot correct the problem?
        We have a TA7002i and TA8002i with the same issue(black bands).
        • Necrocannibal
          • May 2008
          • 212
          #109
          [ATTACH=CONFIG]50521[/ATTACH]
          That's exactly what ours was doing and we replaced the belt with an older style belt and did the bulletin with the mylars. It has done it maybe twice since we did this and never while we are there so we just go clean everything and make sure it looks good.
          Sent from my SM-N986U using Tapatalk
            • Jul 2014
            • 14
            #110
            Interesting enough, both started this after PM Kit was done.
            Thanks for the advice. Will try an old transfer belt and keep cleaning😁
            • Necrocannibal
              • May 2008
              • 212
              #111
              Thanks for the advice. Will try an old transfer belt and keep cleaning[emoji16]
              Yeah if you still have the old ones put them back in and it should stop it.
              • Necrocannibal
                • May 2008
                • 212
                #112
                • cmpelser
                  • Jan 2008
                  • 173
                  #113
                  I am still battling with this problem on a 9002i on and off for 2.5mil on the counter. every time I replace the maintenance kit, it solves it for a while, then it just returns. I must also add that I also do not feel comfortable with the "new" type transfer belt. Also, the old belts never had problems staying in the center.
                  • Ropariva
                    • Mar 2016
                    • 693
                    #114
                    • Necrocannibal
                      • May 2008
                      • 212
                      #115
                      Yeah sounds like our issue. It only does it every once in a while and it's impossible to trace down. We've replaced everything like you as well and it still does it sometimes. The only thing that made it almost stop doing it was an older style transfer belt.
                      • lanierboy
                        • 149
                        #116
                        You have probably been told this already but I cant see it posted, With the new transfer belts there is an issue with them tracking off centre. in the transfer belt kit you should get some pieces of mylar to stick on the frame and you have to run copies and then check that it is running 10mm each side (if i remember correctly). if it runs to the edge it grounds out causing the line. good luck.
                        • rapo_tech
                          • Feb 2019
                          • 114
                          #117
                          TA3500-4500-4501-6500i-6501i_belt skew correction after replacement.pdf
                          But I had different effect on print before adjusted the skew.
                          scanned copy of open lid.pdf
                          Printed black was not solid...
                          • toddanderson
                            • Dec 2005
                            • 238
                            #118
                            Are you guys still seeing this black band issue ?
                            I am not finding the transfer belt is pitting a ring around the drum, I think the transfer belt is arcing to the drum, causing drum damage.
                            You have to look real close at the drum and there is pit marks on the drum.
                            This machine has been doing this off and on and will stop doing it for months and then start doing it again. It is very sporadic and usually only does it once or twice a day or usually only a couple of times a week. Kind of looks like high voltage shorting out for a second and we put a new kit in it not too long ago, it did it before and after the kit. I have attached an example of it and paper is traveling in direction of the arrow I put on the sheet, we told the customer it is hard to diagnose if it only does it a few times a week.
                            • Necrocannibal
                              • May 2008
                              • 212
                              #119
                              We only have one machine doing it and ot only does it once or twice every month or so.
                              • fishleg
                                • Mar 2009
                                • 426
                                #120
                                I have that exact issue.. belt looked centered to me but I have that pitting on the near edge of print.
                                Did a new belt fix it? Gonna replace drum/belt then make sure it's centered it looked centered to me.
