Kyocera M6235cidn color registration problem
  • martinkrys
    • Feb 2011
    • 29
  • ihatefinishers13
    Senior MFP Technician
    • Feb 2020
    • 696
    I had something like this on that model. Initially found the transfer unit was skipping, and that resolved a noise, but was still showing registration shift. After that, tech support told me to replace the main board. It was chargeable so the customer(inter-territorial) upgraded.
      • 23008
      How many times consecutively did you align it. I've had it take 15 times or more to get into range. =^..^=
      • jtruz76
        • Feb 2020
        • 1
        Good morning martinkrys,
        One of my co-workers ran into that. He contacted the Kyocera Technical Support hotline and they provided a reset file called...
        Reset File For ColorShift(SN_RC1xxxxxxx).capt I personally have not tried this yet, but it worked for him. This system won't allow me to upload it because of the file type ".capt". I can email it to you if want. Send me a message to... cbijamest@gmail.com Attached are before and after samples that my co-worker sent to me last September.
        • martinkrys
          • Feb 2011
          • 29
          6 times
          • martinkrys
            • Feb 2011
            • 29
            I wrote You a message, thanks
            • martinkrys
              • Feb 2011
              • 29
              fFirst of all, I thought it was just a transfer belt issue, which, by the way, was broken and made a lot of noise because of the worn bushing
                • 8144
                Originally posted by martinkrys
                Try updating the firmware then run U468 if this model has that sim code ?
                • martinkrys
                  • Feb 2011
                  • 29
                  There is no sim 468 in a M6235cidn
                  • martinkrys
                    • Feb 2011
                    • 29
                    You were right - I did 15 times manual color registration with extreme values and this resolved a problem. Btw, there is no reset FW or reset file for this type of machine
                    • KYO_OEM
                      • Aug 2011
                      • 715
                      You has to ask kyo support for the reset *.capt file.
                      My *.capt file does not work on your systems because it`s depended to the first 3 digits from serialnumbers.
                      Send status page to your kyo tech und ask for registration reset file.
                      • eddie110171
                        • May 2012
                        • 133
                        Have you tried aligning it manually? It takes a blue colored light to do it correctly.
                        • ntbann
                          • Jan 2012
                          • 628
                          Or use the camera on your phone. It makes so you can see the yellow in the blue.
                          • copykat93
                            • Oct 2021
                            • 277
                            What process, or simulation are you using to manually adjust this registration?
                            • martinkrys
                              • Feb 2011
                              • 29
                              Under menu settings, You can chose between automatic and manual color registration adjustment
