ECOSYS P2040dn fuser
  • Hansoon
    • Sep 2007
    • 3389
    Not being a KyoGuy I have two questions about the fuser of the ECOSYS P2040dn.
    1) Is it worth the trouble to replace the film only with after market films?
    2) Any instructions please how to remove the fuser unit? I have never seen this printer before, but must go to a remote customer and like to avoid embarrassing situations. Thanks
    Hans
  • richs
    • Nov 2008
    • 264
    Re: ECOSYS P2040dn fuser
    Hans
    Check youtube .Videos there.Some say replacing film works and other don't.
      • 23009
      The main problem with those fusers is the teflon sheet, between the heater and the film. We were a dealer, so we just submitted everything for warranty.
      Some of the folks here say removing the teflon sheet, and applying a different lubricant works (like the HP LJ4000 fusers, no teflon sheet), I've never tried it myself.
      When the teflon sheet is mostly intact, I have cleaned then applied Toshiba fuser film oil, and it works in the short term. In these cases, I always ordered the new fuser, so it didn't have to last very long. I don't really know how it would last.
      It's disappointing that so many manufacturers have chosen to use this technology. =^..^=
      • PiniuBudyniu
        • May 2023
        • 16
        Not worth repairing. Tried. Used many different parts and oils / grease. Short term solution. Europe has extended warranty due to fuser failures, so we push everything back. Last month one of Kyo reps told me, this machines are being killed by Kyo, because even newer FK are sh*t.
        • ebulich
          • Jul 2010
          • 46
          Have done numerous repairs of these machines and have them back up and running with little issue. The hardest part for me in Australia was getting the grease. I use UniFlor 8172 which is freakishly expensive. I strip all the teflon sheet off. Clean everything with platenclene. Smear ample grease across the guide and re assemble the fuser.
          I re-use the OEM Kyo fixing sleeve. Have never had to replace the sleeve.
          Don't purchase any of the Chinese fuser greases, they are all rubbish.
          Its a 30 minute job, the longest part is cleaning off all the silicon oil during the tear down of the fuser. I also clean the inside of the fixing film with a rag soaked well with platenclene.
          There are numerous videos on youtube on removing the fuser unit.
          Good luck.
          • copier tech
            • 8170
            Hans
            Since this is a remote client I wouldn't risk after market parts.
            Here's the service manual.
            • JR2ALTA
              • Feb 2010
              • 2033
              Hey BC, I enjoyed our dinner last year in Novi! I would like to blame manufacturers, too, but as I understand the move from heat "rollers" to "belts" is a result of holy bible Energy Star mandates. Is this true?
                • 23009
                I enjoyed our dinner, too.
                That I don't know. I do know that trademarks play a huge role in what technology is used in any particular machine. I was working on Canon in the 90's when they were using the ceramic drums. They were rated for an astounding 2M images, and they could do it too ... if your enduser didn't reach into the machine with sharp implements. And they were crazy expensive: $2,000+ USD. Only Canon & Kyocera used them. When they came down is size, they also came down in price ... with the same caveat: they're easy to scratch.
                When I was complaining to the Toshiba Tech Rep about the crappy Toshiba film fusers, he said that the manufacturer is "committed" to using this technology. =^..^=
                • Hansoon
                  • Sep 2007
                  • 3389
                  Thanks guys.
                  How does this printer know when the toner cartridge is empty? Chips, sensors?
                  Hans
                  • Larhal
                    • 584
                    Thanks guys.
                    How does this printer now when the toner cartridge is empty? Chips, sensors?
                    Hans
                    Combination of the toner chip count and the developer level sensor
                    Larhal
                    If all else fails read the Service Manual!
                    If that fails, meet me at the pub and we will discuss it.
                    • pclogicnz
                      • May 2021
                      • 3
                      Does anyone know if the fuser unit for the replacement printer for this model is the same or a better model? the PA4000X is the replacement model.
                      • KYO_OEM
                        • Aug 2011
                        • 721
                        FYI,
                        Common for all models
                        The FK unit would modified
                        we`ll see if it works better
                        • tmaged
                          Owner/Service Manager
                          • Oct 2008
                          • 1887
                          Originally posted by KYO_OEM
                          FYI,
                          Thanks for the info. I've been wondering if they have made any changes to these units.
                          Hope that helps !
                          -Tony
                          www.dtios.com
                          Become a fan on Facebook
                          • tonertech24
                            • Apr 2025
                            • 1
                            Hey guys, great thread, just what I needed – got a customer visit coming up for a P2040dn chewing paper, and I have a bad feeling it's the fuser. Thanks Hansoon for asking and copier tech for the manual link!
                            Reading through here – yeah, same old story with these FK-1150/1270 units. Tried rebuilding films on similar models a couple of times myself – what a pain. Totally agree with blackcat4866, that damn Teflon sheet is evil.
                            The tip about UniFlor 8172 (thanks, ebulich!) is interesting, might look into sourcing some if I get really stuck. But yeah, those cheap aftermarket films/greases... nah, like PiniuBudyniu said, they don't last, and I don't want the angry customer call-back. Especially for a remote site like Hansoon mentioned. Probably easier just to swap the whole unit if the budget allows.
                            By the way, saw the post from KYO_OEM about the updated FK-127x. Anyone actually installed one of these yet? Did Kyocera *really* fix anything, or is it just marketing and they'll die just as fast?
                            And yeah, those C6xxx codes on these fusers are basically expected at this point.
                            Anyway, appreciate all the info and shared experience here! Helps figure out the best approach.
