Konica c224 e can't access service mode
  • jotunn
    • 632
    #721
    Originally posted by a7mad-989
    Hello everyone,
    I need help with generating a CE password reset code for a Konica Minolta bizhub C3300i.
    Any help or reset code would be greatly appreciated!
    Thanks in advance.
    Hello,
    your request code is expired:
    The entered CE Password Reset Request Code cannot be used due to the expiration. (MFP date in the code: 2025/07/30)
    You need to prepare fresh request code.
    Also, for users who do not actively support the forum, the service is available only upon payment.
    Regards
    • a7mad-989
      • 16
      #722
      Originally posted by jotunn
      Hello,
      Regards
      Thank you for your reply.
      I don't mind paying for the service — that's not a problem.
      However, my issue is that the printer keeps showing the same CE Password Reset Request Code every time,
      Is there any way to still generate a valid reset code using the current request code?
      Appreciate your help — let me know how to proceed with the payment as well.
      • Synthohol
        Certified Konica Expert
        • Mar 2016
        • 5885
        #723
        have you checked the time and date on the copier?
        • Zoran
          • 52
          #724
          Dear Jotunn
          Can you provide the codes for these two password reset requests? The requests were made 2 days ago. I will donate 5 euros...
          A7AH127000434
          00:20:6B:3A: D8:41
          SA9LG-2HP34-2KWW9-XG2GS-GCAX6-2G8YD-ENJQH-AYDN5
          A7AK021001377
          00:20:6B:9B: DB:3A
          GKENZ-ZQQS8-QASDC-23JDS-CL33E-CG8YD-ENJQH-AYDNT
          • jotunn
            • 632
            #725
            The request code is generated based on the device's real-time clock, and the current date is encoded into it as well. Consequently, the code should be different with every new attempt. It is possible that generating codes one after another on the same day could result in the same code, but on the next day, the codes should be different.
            Try the reset code below – it was generated with the date contained in the code (20250730). Since you claim the reset code is always the same, perhaps this one will work.
            MFP Serial Number AAJT021203934
            Reset Code 5PGWJ-FS9QL-FTM3H-F4YM8-32DMT-WG8YD-ENJQG-4ZTBV
            Regards
            • jotunn
              • 632
              #726
              Originally posted by Zoran
              Dear Jotunn
              Replied via PM.
              • a7mad-989
                • 16
                #727
                Regards
                thaks i will try and back
                • markos_garcia
                  • 5
                  #728
                  Hello,
                  Your machine has wrong date and time set, I don't know if the reset code will work for you, however you can try:
                  MFP Serial Number AC74011001090
                  Reset Code P3D5X-J8S8S-LKYMU-7N8Q9-EBNEF-GG8YD-EMJRG-EYDLB
                  Regards
                  hello, thanks for the response
                  I tried to enter the code you sent me, but it didn't work. And I don't know how to change the date if the administrator has also changed. Do you know of any alternatives to this?
                  • jotunn
                    • 632
                    #729
                    Take a picture of the newly generated code and put it here, we will try again.
                    • a7mad-989
                      • 16
                      #730
                      I tried the reset code you previously gave me, but unfortunately it didn’t work.
                      Then I noticed my CE Password Reset Request Code has changed.
                      Here’s the new request code from my machine:
                      B55DU-MXA2Y-DBZSZ-2CF7P-B5Y5F-S6BYD-ENJQH-AYTFZ
                      Please let me know if we can proceed with this updated code. I’m ready to make the payment.
                      • a7mad-989
                        • 16
                        #731
                        • jotunn
                          • 632
                          #732
                          New reset code:
                          Reset Code 8MMRG-Y4QUC-EXRDT-JWZSQ-K9B2C-9G8YD-ENJQH-AYTHB
                          Regards
                          • markos_garcia
                            • 5
                            #733
                            This is the new code I generate, for you to review and try again, for the support thank you.
                            • jotunn
                              • 632
                              #734
                              Ok, thank you.
                              Try this reset code:
                              Reset Code HEQF5-7PCJH-NLBRP-3NHH5-HANCW-WG8YD-EMJRG-EZDHV
                              Regards
                              • markos_garcia
                                • 5
                                #735
                                Ok, thank you.
                                Regards
                                I ALREADY TRIED THE NEW CODE AND I WAS ABLE TO ACCESS, THANK YOU VERY MUCH
                                I will be bothering you with other equipment that I have that same problem​
                                I will gladly make my payment in the PayPal account.
                                thanks
