Bizhub 458 with stained edges
  • Cristian Gomes
    • Jul 2025
    • 3
    My printer has stained edges and I don't know if it's a configuration problem or a part problem. The problem only occurs when scanning and copying.
    This gallery has 1 photos.
  • Brad6784
    • Mar 2015
    • 77
    Hi, if this is only happening when scanning or copying this must be to do with the scanner unit. To me it looks like the mirrors are out of alignment, is the skewed image on the original or is the machine skewing the image as well?
    • Synthohol
      Certified Konica Expert
      • 5824
      lift the front left corner of the scanner and make a copy.
      looks like someone used the copier as a table or stepstool and trapazoided the damn thing.
      • copyman
        Owner / Technician
        • Sep 2005
        • 4697
        Good suggestions from others.
        What about copying with original placed on glass?
        • Cristian Gomes
          • Jul 2025
          • 3
          Apparently it was during transportation here. I noticed that there were signs of impact on the lower parts of the printer. I will contact the seller and request a refund.
          • Ziggy
            • Feb 2018
            • 731
            you can try taking off upper left cover and loosen all the screws behind that cover , Lift up on front left of the scanner and while holding it up tighten up the screws. This may help but if it was hit to hard the frame my be bent
            • copyman
              Owner / Technician
              • Sep 2005
              • 4697
              Like the others said you should be able to lift that corner up. Something heavy was shipped on top of copier and pushed that left front corner down.
              • copier tech
                • 8144
                If there are signs of damage don't attempt to repair it, there may well be other unknown issues. Yes get a refund!
                We offer a bespoke service to supply the most popular printer firmware so please contact us to discuss your requirements.
                • kingarthur
                  • 1355
                  Definitely, don't attempt any of the repairs suggested here, the person who supplied it may try and put the blame on you
                  • copyman
                    Owner / Technician
                    • Sep 2005
                    • 4697
                    Depending on how severe the damage is I would attempt the repair since it's a fairly common issue when machines are shipped. I would make the seller aware you are going to try and repair and if it don't work will want a refund. I'm sure it will be ok with them before a refund. *Take detailed pics before you do anything!
                    • aberock
                      • May 2022
                      • 124
                      print from system all normal right ?
                      looks like scanner is bent down than normal position . give that scanner a good lift to normal position should be solve the problem .
                      • copytechman
                        • Nov 2008
                        • 942
                        Definitely bad scanner bend or warp there agree with what others have stated.
                        A.
