Altalink 80XX Series special Altboot method
  • Hassann
    • Jul 2023
    • 75
    Re: Altalink 80XX Series special Altboot method
    Originally posted by hnami
    No.hdd image is so run your device.after restore image to hdd make forced_altboot whith two file FORCED_UPGRADE & DISABLE_DATA_BACKUP in your usb device in altboot folder i learned in forum how to make this files.
    I don't know how to restore image to hdd in right way can you tell me how to do that pls
    By the way to tried using another hdd from another machine but i got the same message
    " unable to decrypt dlm . Perform special Altboot to upgrade the device
    • Hassann
      • Jul 2023
      • 75
      This file image hdd for c8045_55 in your link https://1drv.ms/u/s!AnN361G6j6LzbtwI...GMuUQ?e=e7RKhx
      Is it work with c8030_35
      • hnami
        service technician
        • Nov 2023
        • 168
        pay attention
        It is enough for you to have a backup of a hard disk that has the boot files and load it to the formatted hard disk. Then by creating a USB with the Altboot folder and having the full version DLM file that is available in the forum And two files FORCED_UPGRADE & DISABLE_DATA_BACKUP in the Altboot folder, you can return the firmware to CWIS and there is no need for filesSWUP.USB. SWUP files are only available on the GSN site and only Xerox experts have access to them.
        • hnami
          service technician
          • Nov 2023
          • 168
          #19
          Originally posted by hassann
          this file image hdd for c8045_55 in your link https://1drv.ms/u/s!ann361g6j6lzbtwi...gmuuq?e=e7rkhx
          is it work with c8030_35
          yes.its work for all altalink device
          • hnami
            service technician
            • Nov 2023
            • 168
            #20
            Restore hdd image by active disk image software tools.its free to download and cracked
            • hnami
              service technician
              • Nov 2023
              • 168
              #21
              Sory i can not open the link but i put a link in this forum as hdd device image for altalink try to restor this on new hdd or formated hdd.I promise this way is best for you
              • hnami
                service technician
                • Nov 2023
                • 168
                #22
                Hello friends
                Please use the following link to restore Altalink b 8055 hard partitions,
                DiskImage1.adi
                • hnami
                  service technician
                  • Nov 2023
                  • 168
                  #23
                  hi my friends:
                  also the link is for 81xx series altboot full version try to download firmware as this link:
                  Drivers & Downloads - AltaLink C8130 / C8135 / C8145 / C8155 / C8170 Color Multifunction Printer - Windows 11 - Xerox
                  • Detonation
                    • Feb 2010
                    • 404
                    #24
                    hi my friends:
                    This link is for the upgrade, not for the full altboot.
                    • Detonation
                      • Feb 2010
                      • 404
                      #25
                      Well, there is even 'software_upgrade' in the file name. The altboot files have 'ALTBOOT' in the file name. The 119.xxx ALTBOOT files are 632MBs in size.
                      • Hassann
                        • Jul 2023
                        • 75
                        #26
                        hi my friends:
                        Hello sir
                        Thank you for caring , but Unfortunately the problem is not solved i have tried everything but nothing fixed
                        • Hassann
                          • Jul 2023
                          • 75
                          #27
                          Hello sir
                          Do you have the full software for c8030 ?
                          If you have pls send it me
                          • Detonation
                            • Feb 2010
                            • 404
                            #28
                            PM sent.
                            • hnami
                              service technician
                              • Nov 2023
                              • 168
                              #29
                              Hello sir
                              HELLO
                              the full version software 8035 link is in the forum
                              At which stage of the work do you have a problem, so I can guide you
                              • Hassann
                                • Jul 2023
                                • 75
                                #30
                                PM sent.
                                Thanks alot i will try it tomorrow
