Altalink 80XX Series special Altboot method
Re: Altalink 80XX Series special Altboot method
Here are the SpecialAltboot files for the altalink C80xx B80xx family
C8070 https://mega.nz/file/5d1WjByb#bAzQtH...Xph13O-NMdUsO0
C8045_55 https://mega.nz/file/dZ8QFSDS#JJlyZ4...2mzJokX7cyCi7c
C8030_35 https://mega.nz/file/FEcWHBLL#Ivh0DT...O-50XGJIMCZqrM
B8045 to b8090 https://mega.nz/folder/EMFSnSSI#hZoI_L7rMepP2T_cpV4yDg
These files are not practical
The main files are 83 and 1 kb in sizeComment
active disk image software download link
https://dl2.soft98.ir/soft/a/Active....rar?1709505477Comment
These files are not original and do not work
The size of the main files is differentComment
I need to write the sd image to the sd card, write the hard disk image to the hard disk, and then use altboot to install the system. Is this the case?Comment
YES: https://mega.nz/folder/UcEiFSaC#VkttY_sreDFJRzt1XY3lNwComment
My Altalink model is B8145 so i dont know it compatible with your file "XeroxAltalink_B8170_105.014.009.34422".
And i canot find the Altboot Firmware version 105.014.009.34422 to compatible with this SpecialAlboot.
If you have this Altboot version, please sent to me and any suggestion.
I only have "XeroxAltalink_B8145-B8155_ALTBOOT_system-sw#11401301128800#ENG_MOD.DLM"
Appreciated and many thanks!!!Comment
Thanks a lot about your files!!!
i have installed your firmware for my b8075 device. Now I can't log in to the device with the default password "1111" anymore. Please tell me the password for this firmware! Thank youComment
Altboot full version is this links:
AltaLink_C8045_55_ALTBOOT_system-sw103.002.011.14100 - AltaLink C8030 / C8035 / C8045 / C8055 / C8070 Color Multifunction Printer - Xerox for C8045-55
AltaLink_C8070_ALTBOOT_system-sw103.003.011.14100 - AltaLink C8030 / C8035 / C8045 / C8055 / C8070 Color Multifunction Printer - Xerox for C8070
AltaLink_B8045-B8090_ALTBOOT_system-sw10300801114100 - AltaLink B8045 / B8055 / B8065 / B8075 / B8090 Multifunction Printer - Xerox for B8045-8090
you can read this note befor download : https://static1.squarespace.com/stat...x_Firmware.pdf
Good luckComment
