The random thought thread
  • ZOOTECH
    Senior member of CRS
    • 3375
    #1531
    Re: The random thought thread
    Originally posted by Iowatech
    A collection of pictures from the MRO's High Resolution Imaging Science Experiment (HiRISE):
    HiRISE | Image Catalog
    (Open the link at your own peril.)
    (There are a LOT of pictures here.)
    These images are great, just getting starting - sort of like APOD (astronomy picture of the day) from NASA.
    • fixthecopier
      ALIEN OVERLORD
      • 4713
      #1532
      more proof that cats are assholes...
      • TheBlueOrleans
        • Aug 2012
        • 232
        #1533
        Couldn't find an appropriate thread to put this in, and didn't feel like drawing attention to myself by starting a new one:
        After replacing pickup, feed and separation rollers, one way clutches and torque limiter, motor and control board, I find the cause of the intermittent but damn-near constant 15-01 jam from PC-409 to be caused by the mylar guide on the inside of the tray.
        I was alternately ecstatic and very angry. Mostly angry with myself for wasting so much time and money by not seeing the problem the first time. The adhesive portion of the mylar was askew ever so slightly but enough to the point where the feed assembly would attempt to feed the mylar, or it wouldn't pick up paper at all and just throw the jam due to timing.
        Replaced the mylar (because it is at least two years old and in an office with higher than normal humidity 8 months out of the year) because the adhesive had failed partially and the mylar was pointing higher than it should have been. Hasn't jammed since.
        Edit: this issue took four visits over a period of six weeks before I discovered the blasted mylar.
        Last edited by TheBlueOrleans; 08-17-2016, 02:00 PM. Reason: Edited to increase amount of embarrassing information. Shame is a waste of time. Accept the mistake, own it, and move on.
        Somewhere there is a tree working hard to produce oxygen for you to live, NOW GO APOLOGIZE TO IT!
          • 23010
          #1534
          Originally posted by TheBlueOrleans
          ... I was alternately ecstatic and very angry. Mostly angry with myself for wasting so much time and money by not seeing the problem the first time. The adhesive portion of the mylar was askew ever so slightly but enough to the point where the feed assembly would attempt to feed the mylar, or it wouldn't pick up paper at all and just throw the jam due to timing.
          I sure know how that feels. Once you find the culprit, it seems obvious as hell, and how could I have missed it? =^..^=
          • roho
            • Mar 2009
            • 844
            #1535
            • RoyROd
              • Mar 2013
              • 29
              #1536
              I play Destiny on Xbox One, how about you?
              • Iowatech
                Not a service manager
                • 3930
                #1537
                The Schwarzerneger movie explosion supercut!
                Might not hurt to turn the volume down for this silliness.
                • nekowaiidesu
                  • Dec 2015
                  • 65
                  #1538
                  I play Dota 2
                  1v1 ME M8 I'LL REKT U SWER ON ME MUM, and all that jazz.
                  • fixthecopier
                    ALIEN OVERLORD
                    • 4713
                    #1539
                    How a cockroach can effect your prints...
                    • NeoMatrix
                      Senior Tech.
                      • 3513
                      #1540
                      Nah!... It's just a bug in the system. Ctrl-Alt-Del or power on/off....
                        • 23010
                        #1541
                        I had a box elder bug infestation that worked a lot like that. They make a great "CRUNCH" when passing through the fuser. and leave a 25mm greasy spot on the paper. =^..^=
                        • zoraldinho
                          teacher-guide-expert-guru
                          • Mar 2008
                          • 5017
                          #1542
                          Smell of barbecue?
                          • SwisSeV
                            • Jan 2016
                            • 307
                            #1543
                            Im back!!
                            Weather was perfect in the cascades for a week.
                            Got to see the sunrise over the Cascades from Baker summit.
                            I'm very jealous of those of you who live in the Pacific Northwest.
                            • NeoMatrix
                              Senior Tech.
                              • 3513
                              #1544
                              Originally posted by SwisSeV
                              Im back!!
                              [ATTACH=CONFIG]33934[/ATTACH]
                              Good one!...
                              I'm sitting looking at my PC... Looking out the window... feeling a tad envious...
                              My mates an I did a lot of motorcycle riding in the forestry in my early youth.
                              I just reminisce on that feeling of freedom for a few seconds...
                              Ah well, back to reality..... <thud>...
                              • Iowatech
                                • 3930
                                #1545
                                Originally posted by zoraldinho
                                Smell of barbecue?
                                [ATTACH=CONFIG]33930[/ATTACH]
                                Not really, barbecue generally smells good, and a bug fuser fry usually smells awful, and isn't that nutritious either.
