Update C250i from old firmware to latest
  • ps-tech
    • Oct 2023
    • 7
    Hello,
    I need to update some C250i with old firmware (G00-D0, G00-E9...) to latest. Work fine with old firmware (200k-300k counter) but now client want TLS 1.3 and I understand that is included on newer firmware. Are those step below ok to avoid problems with cpu board? any sugestion?
    1 – INSTALL G00-J9 firmware and BOOT ROM
    2 – INSTALL G00-RE mass production firmware
    3 – INSTALL power control CPU2 (LPPP) and MFP controller boot program FW
    4 – INSTALL GC3-RE special program for switch 187 hex40
    5 - INSTALL G00-RF mass production
    Thanks.
  • doinbox
    • Jan 2013
    • 99
    Personally I've always upgraded straight to the latest version and never had any issues. I've always been told to do it in stages but with my extensive knowledge on Linux I know this isn't required.
    • copytechtrouble
      • Nov 2020
      • 99
      yeah same here. I've gone from B6 firmware on a 250i to the latest RF firmware with any issues.
      • occus
        • 333
        I always go straight to the latest. But I have already made the experience that it can make a difference with specific settings if you upgrade in stages or not.
        • Albonline
          • Sep 2008
          • 1147
          in a shop environment, i went to latest with boot rom, then any special firmware , then set switches . never crashed any .
          • ps-tech
            • Oct 2023
            • 7
            Thanks all, i will go with boot rom first, then RF firmware.
            • Woxner
              • Jul 2011
              • 845
              Be sure to update movie data and set sw 25 to 40 or things may not work properly
              • copyman
                Owner / Technician
                • Sep 2005
                • 4665
                I've also installed F/W from old to latest without any issues.
                Speaking of "i" series movie FW, Looking on kon/min dealer website I don't see a specific movie FW under base or special FW? Is it included in the base FW? I did see the OCR / Font data but not the movie like with the 8 series FW.
                Thanks in advance
                • Ziggy
                  • Feb 2018
                  • 710
                  Movie Data can be found under the Base Firmware Package Tab.
                    • 8136
                    Yes, you can go straight from an old version to the latest without any issues.
                    Firmware Readme C250i C251i C300i C301i C360i C361i G00-RF.pdf
