Konica c224 e can't access service mode
  • Mr Bo
    • Mar 2023
    • 28
    #46
    Re: Konica c224 e can't access service mode
    Originally posted by jotunn
    You're welcome, good luck.
    Dear Jotunn,
    I have successfully entered, thank you very much
    In the process of working with customers, I often encounter these problems caused by technical staff. So I looking forward to your support if I encounter cases like this.
    Best regards
    • computek
      • Mar 2023
      • 9
      #47
      Originally posted by Synthohol
      its supposed to beep, ignore the sound.
      apologies was away at weekend.. thanks for the help and I [finally] managed to get the service code to work... It looks like now though I need to change the CE Password as I get the following [See Attached]
      Of anyone could help me with the reset code I'd appreciate it thank you ..
      • jotunn
        • 616
        #48
        Reset code:
        ZMRQH-BEBYP-FMMDP-CVAUY-6SKKA-6G8YD-EMZQG-MYDNT
        • computek
          • Mar 2023
          • 9
          #49
          Reset code:
          [ATTACH=CONFIG]57141[/ATTACH]
          Thank you jotunn - much apreciated..
          • Mr Bo
            • Mar 2023
            • 28
            #50
            Second reset code
            AA6V041002651
            EPMNQ-6QL5D-W9HF2-VZXUB-4EPTQ-6G8YD-EMZQG-MYDLF
            [ATTACH=CONFIG]57130[/ATTACH]
            Dear Jotunn
            please support me with reset code,thank you
            AA6U041004388
            MAC : 00:20:6B:6F:6E:BB
            REQUEST CODE: DHMF5-PHKSB-7KK3N-S67ZH-NTXL7-CG8YD-EMZQG-MYTHR
            • jotunn
              • 616
              #51
              Originally posted by Mr Bo
              Dear Jotunn
              AA6U041004388
              Your reset code:
              HLXSD-TH33Q-LS4R6-Y67QW-PUBUW-WG8YD-EMZQG-MYTLP
              • Mr Bo
                • Mar 2023
                • 28
                #52
                Your reset code:
                Thank you Jotunn
                • francesco.giu
                  • Mar 2023
                  • 1
                  #53
                  [QUOTE=jotunn;2048562]Everything seems to be ok.
                  Hello, sorry for the inconvenience, I have a problem with a konica minolta c300i, the ce password is blocked
                  I have the registration code but I don't know how to retrieve the one to enter to unlock it.
                  can you help me?
                  THANK YOU!!!
                  this is the registration code and the serial number
                  6EVPM-4GX25-79EV4-WVYRS-HRP8C-SG8YD-EMZQG-MZTBX
                  SN AA2K121004956
                  • khuongoikhuong
                    • Apr 2023
                    • 2
                    #54
                    Jotunn, I have Konica C558, can you please give me the reset code? Thank you so much, you're amazing
                    SERIAL: A79K11016591
                    REQUEST: UMQTG-5URVU-VTHFC-7BBJW-KU634-SG8YD-EMZQG-QYTHB
                    • jotunn
                      • 616
                      #55
                      OK, but I still need the MAC address of the machine.
                      • khuongoikhuong
                        • Apr 2023
                        • 2
                        #56
                        Here is is: 00:20:6B:3D:32:4E
                        Thank you mucho!
                        • jotunn
                          • 616
                          #57
                          Thank you mucho!
                          MFP Serial Number A79K011016591
                          Reset Code J85WE-ULSVF-UUD9V-N72SB-F58HB-SG8YD-EMZQG-QYTL7
                          • piksel1983
                            • Oct 2018
                            • 38
                            #58
                            Hi guys, my c258 dont enter SMode
                            Please help
                            Printer serial a7py021016888
                            MAC 00:20:6b:b6:23:20
                            Ce pass request: 8Jakx 4tla9 lmky3 wn9bv jlguf gg8yd emzqg qzdlr
                            Wysłane z mojego Mi 9 SE przy użyciu Tapatalka
                            • jotunn
                              • 616
                              #59
                              Please help
                              Your reset code:
                              MFP Serial Number A7PY021016888
                              Reset Code TNCSR-PJ8FG-U2VB3-F57BV-F9HM2-GG8YD-EMZQG-QZDLH
                              • piksel1983
                                • Oct 2018
                                • 38
                                #60
                                Your reset code:
                                Thank U so much!! It worked, changed to standard pass.
                                One more time, big thanks!
