BizHub C650i randomly cycles throughout the day
  • BCE75
    • Mar 2017
    • 3
    We have a BizHub C650i in our department and we're not sure if it's acting the way it's supposed to. Several times a day (like... every 30 minutes at least), the copier fires up, the outfeed tray raises up, the lights in the top scan tray light, and it beeps. Then it goes back to just sitting there. The display screen on the front is always on, and no one is walking by to wake it up. It acts like it's receiving a print command, but it's not. Is it supposed to do this or is there some setting we can change to make it stop. Our department is usually pretty quiet, and this copier behavior is kind of annoying. It is on a print server, if that makes a difference. IT says it's fine.
    Thanks!
  • Synthohol
    Certified Konica Expert
    • 5849
    It seems you have ghosts.
    try disabling any protocols not used like ip6 or snmp see if that helps.
    maybe some device is polling it?
    • copyman
      Owner / Technician
      • Sep 2005
      • 4723
      I would start by calling in a Priest
      Seriously not sure what would cause your issue but can offer my thoughts on it:
      If air print is turned on maybe a phone is waking it up?
      Also you can change the timer settings in admin mode, power save, turn on or off sleep mode, etc. Try some different settings until one works. There may be a energy save setting that wakes machine up throughout the day to rotate fuser rollers?
      • tsbservice
        Field tech
        • 8020
        Thanks!
        Too hard to diagnose over the internet you need qualified tech to visit machine and check settings errors etc.
        • Albonline
          • Sep 2008
          • 1151
          are all installed apps, and the unit itself properly licensed?
          • Woxner
            • Jul 2011
            • 851
            There was a bug in one of the firmware that did this. Machine reboots. I have Been standing there when it happens.
            • doinbox
              • Jan 2013
              • 112
              What Firmware version is it currently on?
                • 23009
                My guess is that there is some sort of network traffic that slightly resembles a print job, and is waking up the MFP. The conclusive test is to unplug the network cable for a for hour, then see if it continues. Keep in mind that it's entirely normal for the machine to rotate the fuser rollers periodically so that they don't get flat spots, even if there is no print of copy job pending.
                • Slammers
                  • Feb 2019
                  • 136
                  This sounds like the exact behaviour experienced when somone sends a job into job storage for release later.
                  Is someone using the User Box/Secure Print/ID Print feature or does someone have the incorrect output settings configured in their driver (Printing Preferences -> Basic Tab -> Output Method).
                  If this is set to anything but "Print" the job will get stored rather than printed.
                  • AlaskaCopyTech
                    • Jan 2024
                    • 78
                    Yeah, I have a machine that does this -randomly wakes up and then does nothing. You could go down a rabbit hole but in my experience nothing is wrong with the machine there is just something that wakes it up.
                    • Albonline
                      • Sep 2008
                      • 1151
                      every unit that i changed personality on acted this way. until it was licensed. they will continually try to call home.
                      • occus
                        • 337
                        Do you have a device from the early days?
                        On the first devices this was normal. Then there was a modification with a grounding cable on the display that was supposed to dissipate some kind of electrical charge from the touch panel. But honestly, it never worked for me. The solution is to disable the touch wake function in the settings. After you have to wake up the device from sleep mode using the side button.
                        There was also a firmware bug that would wake the device at midnight.
