Bizhub c250i
  • otphas
    • Aug 2019
    • 119
    Bizhub c250i
    Hi Guys,
    on Bizhub C250i bypass not working, we swapped with other, but error is the same. Any idea?
  • femaster
    • May 2011
    • 1514
    If you can provide the error code, someone might be able to help.
    • Synthohol
      Certified Konica Expert
      • 5847
      turn the bypass back on in unit isolation?
      • kingarthur
        • 1369
          • 23009
          "Not working ... " is a bit too general for me to start hazarding guesses. Can you be a tiny bit more specific?
          • copyman
            Owner / Technician
            • Sep 2005
            • 4719
            I'm sure with 100+ posts on this forum it was an oversight not providing more info. Can only help with more info. We aren't mind readers or detectives
            • Ziggy
              • Feb 2018
              • 770
              look on page 57. the one-way gear it mentions is on the same shaft as the feed roller. be careful there is a pin in shaft that the feed slides on to it falls out very easily. the first time you do this I recommend pulling the bypass off to do this
              • otphas
                • Aug 2019
                • 119
                Hi All,
                i am sorry, forgot to give you a error code. It is C-0211, i tried already to isolate and on again. No luck, as i install another bypass and problem is the same thinking is something with the machine.
                • Duplicator
                  • May 2022
                  • 246
                  Originally posted by otphas
                  Hi All,
                  Service manual says.... "Manual feed up/down abnormality". Please see attached.
                  Worked in IT for 12 years from Helpdesk up to System Administrator. Now working as the IT Manager at a copier company for the last 4 years.
                  If I helped you out, please give me a thumbs up! It helps my reputation.
                  • SAR
                    • Jul 2009
                    • 203
                    Just a theory, but on the 8 series copiers, The C-0211 codes on the Bypass unit were caused by 1 way gears in the Paper Feed Drive assy slipping. The C250i series has a paper feed drive assy too, so maybe try one of those.
                    • copyman
                      Owner / Technician
                      • Sep 2005
                      • 4719
                      Since you tried another Manual feed unit I would look at the paper feed drive assembly (see attached bulletin)
                      • Slammers
                        • Feb 2019
                        • 136
                        There was a bulletin released about the bypass one way gears being installed backwards from factory. Has this machines bypass ever worked or been tested before?
                        • otphas
                          • Aug 2019
                          • 119
                          Hi All, we get this machine used and bypass was not working when we tested. We dont have service history from the previous owner.
